matching tubes
517 Leroy
Sep 1, 2018
12
6
13
55
How important is all matching tubes? I got a Scout 20 8 tuber in trade, works good but has different brand tubes.
It would be ideal if they were all matched with a tube tester but it will work fine with different brands in it as long as they all are good tubes. Sweep tubes are too scarce and expensive to be picky.
Some of the local guys went out and bought tube testers. I repaired one sweep tube amp and found that if you hold an am carrier for several seconds the good tubes start to turn red faster than the weak ones and the duds do nothing. Don't over do it though. Sweep tubes have paper thin anodes.
If anyone wants to trade tubes that turn red for ones that won't, I'm happy to make that deal :) The truth is if you get rid of the ones that don't turn red, the ones that do won't have to work so hard and you'll see more power out. I am a fan of the "red plate" test that 543 mentions above because it's an indication of how the tube is responding to both DC and RF under load. Lots of factory matching is only done with DC. As 543 says, don't over due it with sweep tubes. You only have to key the amp long enough to spot the first signs of color change on the plates. Don't wait for the weaker ones to change color because you already have your results once the first one does.
I finally got to open it to preform the test, they all seem to glow the same but one is dim, then when I key it glows really bright then when I modulate it will go dim. I guess its a bad one.
If it isn't already it will be soon.
The gray "plate" structure inside the glass isn't supposed to light up.
Unless it's a big tube the size of a fruit jar. They're different.
Your Scout 20 is either set up wrong, or some parts have gone bad from 3 or 4 decades of age. There is more than one kind of problem that can cause the tubes to overheat and "cherry", showing color on the plate structure inside.
Reactions: 517 Leroy
Guess I'll get on eBay and start looking for tubes. 6lq6s
I have a bran new set of 4 matching RCA 6JE6A-6LQ6 that I bought from Tube Depot a few years ago for spares to my Kicker 500 Amp (1x3)...Last set of matching RCA's I seen were going for $350+...
Hard to find 4 matching NOS tubes...most are sold as singles or pairs.
The problem with the 6LQ6 tube is it wasn't only popular in CB linears. It was also used in some of the most expensive audio amplifiers ever built in matched sets of 8! If you own one of those 8 tube AF amps, it doesn't matter if the tubes cost $250 each. Those owners will pay anything to keep them alive.
If they were tested in an amplifier, maybe.
A tube tester is good at identifying bad tubes.
A tube that checks good in a tester may still produce a blue flash and break down under load in an amplifier.
Given the odds, I would recommend getting five or six good tubes to run a 4-tube amplifier. We recently fixed up a Maco 750 that used a terribly-rare tube called the M2057. It arrived with eight tubes in it, and three of them flunked my tube tester. Found five more to use that tested okay. One of those went "SNAP" after the amplifier was keyed a dozen times or so. The tester confirmed that this tube now tested bad.Tested okay before that.
Same thing happened to another tube after running it a while.
So now, after starting with a total of 13 tubes, it has eight that work in it.
Only a question of how long before another one goes "SNAP!".
Your mileage may vary. The Maco amplifier is famous for being hard on the tubes.
    BLACKOUT HF
    May 15, 2024 @ 14:55 UTC
