MFJ-815D Cross Needle Meter??
The only time I use the meter is
a.) tuning the rig for the band( its a tubed rig and requires retuning when changing bands)
b.) tuning the antenna (if running a band I don't have a wire up for)
When actually talking I have the meter off, I only look at the ALC meter on the radio. If something should change I would see it there. I want the ALC meter to barely move when talking.
Will the ALC change if the SWR changes?
This is one a few of us use.
Reactions: BJ radionut
I was entertaining for my low budget the old 21-524 model.. $20-35..
These actually were pretty accurate & consistent all through their production runs.
A little hard to read due to size but useful.
Also even though the switch on the unit is marked avg. &pep if you read the description on the box
it says peak power not pep.
  • @ Tim Chambers:
