Mic to Rig matchup Quiz
KC2SWR
Dec 2, 2008
9
2
11
Ok folks, need some advice on which mic to set up to each radio. Here are my mics: D104, Workman 502b, Turner Plus 2, Astatic 1104C
Radios: RCI 2990DX, RCI 2970, Tram D300, SBE Landcommand LCBS-8, Craig L232, Teaberry Stalker XX export, Pace 8193, Royce I 642, Stoner Pro 40, TRS Challenger 1400, GE Superbase, AR - 3500 (4pin, I believe wired for cobra), Midland 78-999, Robyn SB 540D, SBE Console VI, Dak X.
Please give feedback in terms of combinations that you have personally used, or good sounding pairs that you have heard over the air. Thanks!
Rule of thumb is anything with tubes takes a high impedance mic, anything solid state takes a low impedance.
After that it is up to the op to decide which mic sounds best for his voice.
How each microphone sounds on each rig is determined by who tuned the radio. I have used the D104, Workman 502b, Turner Plus 2, rk56, Electro-Voice 602t (built by me) and the Astatic Echomax 2000 on several radios. All the radios tuned at Fine Tune sounded great with all the above, although they sounded best with the RK56 and Echomax and Electro-voice. All the radios tuned by random shops around the country, results varied depending on who hacked the radio up. In general, properly tuned rigs sound clear with any decent mic regardless of impedance, while hacked rigs often need mics with an impedance mismatch to keep from overdriving the audio chip in the rig.
