I never did understand making a 2 driver section amp. How could you possibly not overdrive the piss out of the 4 other transistors without some major attenuation. If you can find them the newer straight 4 pill from TNT wouldn't be a bad amp. It would not put big numbers up with a single final ssb radio, but I bet it would get your name called and be clean and the amp would last a very long time as well. Heck you could even use a radio like a magnum 257hp or stryker 955hp with the HD 4 pill. My brother in law has one of the TNT 4 pill HD amps, not sure the model number, but they do look to be built well and are biased b. JMO but I would look into a straight 4 pill. Leave the driver section stuff alone if possible, a 1x4 aren't too bad, but I promise that a straight 4 pill, while it may not show the same watts as the 1x4, will work just as good and will be clean as you won't over drive it. If ssb dx'ing is what you are after, look around real good, there are a few amps that would work well and are 2 pill amps, like the magnaforce or an original Dave made 2 pill or an older xforce 2 pill HD amp with ssb delay. I love my little magnaforce 350hd and have no issues getting my name called on ssb even when there is a pileup. I can use either my magnum 257hp with a 2 watt dead key and the radio does around 70 watts pep, into my magnaforce 350hd and see around 300-400 pep with it. This is with a 2 transistor amp that still sounds clean on ssb. If it were me and I was looking for a good 4 pill or a 1x4, in would look at the Dave made amps, especially the old school ones in the gold box. I know amps are getting harder to get so when you do decide what you want, make sure it's a good one. There are still deals out there, just have to look around, I found my magnaforce 350hd for $80. Look around on CL, that is where I have found most of my used gear at. eBay is a joke anymore. That and maybe there are some other locals near you that have something for sale. Good luck and hope you get what you want. Like I said look at the newer TNT straight 4 pill HD, they seem to be built like the Dave made and xforce amps. God bless and have a Merry Christmas.
