Hello all, I'm working on an amp with MRF455 transistors. Would someone happen to know what the bias voltage should be for these? I'm reading -12v on the base keyed or unkeyed. This doesn't seem correct, but I'm not sure.
If I had enough information, amp brand, model number, or a schematic I could be more helpful. Unkeyed the voltage should be ZERO volts. I am hoping that your voltage reading of -12v you just have your leads reversed. If you have -12v and you do not have the test leads reversed then maybe you have reversed your power supply.
The posting read as follows: I'm reading -12v on the base keyed or unkeyed.
Last I heard V means voltage.
You are correct about the quiescent currents at 80 to100 ma idle current.
Thanks guys. Sorry, after posting this I figured it out. Yes for class AB approximately .6 volts but adjust for correct current as mentioned. I was trying to figure out how to delete this thread
Thanks again!
Please advise me to what is a good replacement mic for my SR-497HPC... Answer: 497 is "wired like Cobra", so many choices available. That radio does not need a power mic, so purchase a stock "coffin style" mic with a decent cord, like the ones that Astatic uses. The Superstar DM-507 is my go-to. https://www.ebay.com/itm/3050474478...adANq91JSiEEnz8EGqPJRBloTgEyaVsBoCtoMQAvD_BwE $12.99 + .99 cent shipping.
