Mura mic wiring help
43Echo695
Oct 19, 2008
86
7
18
Queensland, Australia
I have a Mura PRX-300 desk mic that I want to wire to a Galaxy DX-2547.
It has a 4 pin plug with an unknown wiring configuration. The 5 core coiled lead appears original, and I want to identify the functions of the cores, ie TX, RX, Audio, Shield.
The cores and existing connections are:
braid (pin 1)
yellow & green (pin 2)
blue (pin 3)
red (pin 4)
I have looked in the usual places on the net without success, any help will be welcomed. Thank you.
43 Echo 695
:headbang
The audio wire on 99% of mics is the one that the braid is wrapped around. So now you know which is shield and which is audio. To determine the rx and tx wires you can follow these procedures:
MIKE WIRING GUIDE
