My Latest Antenna Project
unit_399
EL CAPO
Jun 17, 2008
2,164
3,162
273
ALEJANDRIA, COLOMBIA SA
About 9 months ago, I built a 2-element quad antenna. It worked well until the plastic wire retainers on the ends of the spreader arms broke. I pulled down the antenna and made heavier retainers. 3 weeks later one of the bamboo spreader arms broke, so I hauled it down again. All of the bamboo spreaders were brittle and cracked even though I had given them several coats of spar varnish. So, I decided to redo the whole thing. 6 months have passed, and it's finally done.
The new quad has spreaders made from extruded aluminum tubing and fiberglas rod. Also, it's a direct feed, but I made a connection box so I can add a 1/4 wavelength of 75 ohm cable if it's necessary. I'm going to put it up on Monday. Hopefully this one will last a little longer.
- 399
399: Love it...looking good OM....
Nice scenery at your place too...long way from INDY "ye"!;)
All the Best
BJ
No kidding.
We have cows and horses here, but mountains? Here at the lake, we have MT. Baldy, but it's just a big sandpile.
What band is the antenna for, without a reference point, it's hard to tell it's size.
Looks very well built.
11 meters.
BTW ... on the initial build I used #12 enameled wire that I got from a motor rewind shop. When I pulled the antenna down, a lot of the enamel was missing and the bare copper was corroded. I handled the wire very carefully when assembling the antenna (no kinks, stretching, etc.) I guess the combo of mucho rain and sun down here was too much for it. So this time I used wire with thin teflon insulation. We'll see how it holds up.
- J.J.
very nice and clean looking . im really looking forward to hearing your results with it (y)
nice piece of gods country you got there , beautiful mountain view too . (y)
Finally got caught up enough to pull the guys out of the fields for half a day to get the quad put up. Night and day difference between it and my dipole. 1.3:1 swr on 27.385. I'm very satisfied with the way this project worked out
- 399
FINISHED UP JUST BEFORE THE STORM BLEW IN
looks good. how did you tune it for best performance? ill have to listen for you. what freq do you use for sideband? when i bilt my quad i just drilled a 5/8 inch hole all the way thru the 1 3/4 inch boom and used 2 feet of 5/8 16th wall tubing and drilled crosswise next to it for the other spreader tube. i had to drill thru the boom crosswise in the middle of each 5/8 tube for a small bolt to lock them from sliding out of the boom holes. i slotted the ends of the 5/8 tubing and used a automotive compresson clamp to squeez down on the 6 foot long 1/2 inch around fiberglass rod spreaders to tighten the wire. it looks real clean and works perfect
man that looks nice . did you notice much or any difference in the noise floor ? did you wind up needing to use 9 ft of 75 ohm coax for it to tune ? what are your wire lengths for the elements ?
Booty -
I designed the antenna for 27.385, and the wire length (driven element) is 36.699 feet. Reflector is about 10% longer. At first, swr was off the scale, but when I added the 75 ohm stub it dropped down to 1.3. The 75 ohm stub is 9.2 feet long. I haven't done any tests, but weak signals came up by about 1 to 2 S-units or so over my dipole. Guys I talk to all the time in the US said I also came up by 1 - 2 S-units on their meters. F/B Ratio isn't important to me because there are very few other (if any) 11 meter operators here.
- 399
399 i think you maybe missed my post above bootys. my wire was 432 inches for the driven and 448 for the reflecter. a 1/4 wave of 75ohm should be 9 feet times its velocity facter or more like 81 inches if its vf is 75%. stations in front would hit with 20 and in back they would hit about a s4. the better the tuning of the reflecter the more forward gain you get
