need help again with mic wireing , t command
i have anouther question ,, after looking at the websight
http://www.hardtimez99.com/SECRETCB29/bookz/SECRET_CB_VOLUME_3.pdf
i see where it says
tea berry (t ) command
adjust L15 and L12 for maximum RF power
adjust VR5 for 100% modulation or cut D14
VR6 : modulation meter adjustment
VR4 : RF meter adjustment
connect pin 19 or IC3 to 4.84v source for new frequencies ( channels 1-26 )
ok i looked in my radio and saw that the ( D14 ) had already been disconected ( not cut but one side un-soldiered ) , i dont plan on adjusting any of the things they say to adjust , because as yall know i dont know much about this all ..
but i do feel that i can maybe do the last step ( connect pin19 to a 4.83v source ) ,, but what im wondering is , what does it mean by new frequencies on channeks 1- 26 ?? and how will this help
Ok you need to be very careful when soldering around the PLL chip it can easily be damaged by static-electricity or by overheating if you hold the soldering iron on the pin for too long! Also, they don't mention the use of a pull up resistor, which would be recommended to restrict any large current flow (unless there is one built into the PLL chip). For what you will gain for the mod is it really worth risking the rig.
See if you can find a copy of the "screwdriver experts guide to cb radio"
not sure of the author and the "CB Eprom Data Book by Martin Pickering", they will help you understand the inner workings of the radio and how the voltages on each pin of the PLL chip control its frequency.
Do some reading, and buy some cheap old 40 channel cb's and play around
with them, rather than risking your only working set.
Congratulations on wiring the mic, it feels good when you do something for the first time and it works, well done!
Cheers Mark (y)
26ML205
Okay. The radio's mike socket uses pin 1 for audio, pin 2 for transmit and pins 3 plus 4 both as ground.
Audio for the factory cord is white, with shield wrapped around it. Goes to pin 1
Transmit wire is red, goes to pin 2. Just beware hundreds of Volts DC on that pin while receiving.
Blue gets combined with the shield. Should probably bridge pins 3 and 4 together inside the mike plug. This pair of wires goes to pins 3 and 4.
Reactions: ShadowDelaware
    I am beginning the packing process...XENIA bound Going "Lite": this year....2 items for sale...Rig #1 = FT-920/Gud to Ex condition/Hand Mike/pwr cord/manual (NO BOX) ... #2 = My 1 owner FT-950....EX condition...Original Shipping Double Box/Factory Manual/Never used hand mike...Booths 9107-9111...Ya'al come by say hello...
    Incoming Region Produces X3 Solar Flare
    May 15, 2024 @ 14:55 UTC
    Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned
    Everything is El Dead-o. Joy!
    Please advise me to what is a good replacement mic for my SR-497HPC... Answer: 497 is "wired like Cobra", so many choices available. That radio does not need a power mic, so purchase a stock "coffin style" mic with a decent cord, like the ones that Astatic uses. The Superstar DM-507 is my go-to. https://www.ebay.com/itm/3050474478...adANq91JSiEEnz8EGqPJRBloTgEyaVsBoCtoMQAvD_BwE $12.99 + .99 cent shipping.
