Need Help Identifying Plugs On An ANTENNA ROTOR
Ez2cDave
Nov 22, 2012
50
20
18
I need help identifying the plugs on an antenna rotor.
The unit is a WILSON WR-500 and I need to make a cable for the Control Box to the Rotor.
I have pics of the plugs & socket . . . I do not have the plugs shown in the last pic.
The plug on the rotor has a threaded collar to lock the cable in place after the plug is inserted.
Who were / are these plugs made by and are there any current items that will work ?
Thanks, in advance !
The control unit uses a standard octal tube socket so you are looking for an octal plug to mate with it. Lots of old gear had those as accessory plugs and jacks. The first one looks like a modern Yaesu connector but not 100% sure on that.
Thanks for the tip on the "Octal" plug . . .
I suspect the one on the rotor will be a "bear" to locate, if it's not the Yaesu plug.
This rotor is from the mid-1970's, I think.
I found some specs for Octal plugs . . . Looks like the "Pattern 88" is the one, provided I can match the diameter.
  • OCTAL PLUGS - Technical_Specs_OP.pdf
The plug that fits the control box was originally known as "86CP-8" when they were made by Amphenol. Same one that a Browning CB transmitter has on it, and plugs into the rear of a Browning receiver. The metal shell has a separate part number, just can't remember it right now.
There used to be a guy on qrz.com who sold the one that looks like a mike plug with a gland condition. Never did learn the original manufacturer of that one, or what they called it.
Seems to me this rotator was made be "Emoto" in Japan. It's the brand that Yaesu bought and rebranded a few years later. Odds are that anyone who has it will refer to that plug as a "Yaesu" and not by the older names.
I think it is called a Jones Plug but I did not see a picture?
SIX-SHOOTER
Sorry for the delay in replying. I was out of state for my Mother In Law's 80th birthday and just got in the door about an hour ago .
I will definitely use the info that has been provided to aid my search for the correct plugs !
Looks like the plug that mates to the rotor may be an 8 pin mike plug??? Hard to tell how big in diameter from the picture.
73's
David
The rotor plug is definitely NOT a microphone plug . . . It is MUCH Larger.
I took some photo's with a ruler to give some scale to it
Reactions: Dmans
I did manage to locate a PDF of the WILSON WR-500 Manual . . . Attached.
  • Wilson WR-500 Manual.pdf
Ez2cDave,
That does put it in perspective.
Is it a possible smoother journey to replace that "socket" with something more readily available? Surely the rotor will have to be disassembled but considering the manufacturing date of this unit, might be at least due some fresh grease!
Good luck!
73's
David
