I traded for a home made power supply which works very well. It's pretty heavy and looks to be very well built. Well any way my question is how can I check and see how many Amps it is? I tried it out with a Galaxy 33 and a 250 watt amp and it ran both of them with out any problems, but still like to know how to check and see what the Amps are. I don't have any high dollar test equipment about all I have is a good Volt/Ohm Meter.
Could someone please explain and I go about checking the Amps?
Thank you...
Thank you...
