Needle swings backwards, power is too low to calibrate SWR meter and scratchy audio
I had this it was the TX signal meter VR, variable resistor like a silver horseshoe, you need to find yours on a schematic.....also the RX signal VR was out.....I actually did mine with the rig upside down and set the needle to the right, when I turned the rig right way the needle was going to the left!....had to do it all again...
  • @ Mark Malcomb:
    Hello BJ. Been a long time since I've been on. You doing well? Mark Malcomb
  • @ Naysayer:
    I’m
  • @ kingmudduck:
