NEW GMRS/MURS Base Antenna Installed
SIX-SHOOTER
ICOM CENTRAL.7610,9100,PW-1,HEIL FIN & HEIL PR-781
Oct 2, 2010
1,239
1,616
173
Macclenny,Fla.
My wife purchased me a New GMRS/MURS Base antenna at Christmas 2022 & I just got it installed on a 30ft mast pipe last week. I can hit repeaters about 30 miles away It's a HARVEST GP1443L antenna. The only weird part was trying to actually connect the PL-259 Connector to the SO-239 connector on the bottom of the antenna. There are Zero Instructions just a spec sheet with the antenna which is rated at 300 watts & weighs less than 2lbs. I am very pleased with it so far. It hears & transmits very well it appears & I'm using around 30 watts of output with a 1.2.1 SWR.
SIX-SHOOTER
W4KVW
WRMX520
Reactions: whiteastro
This antenna is advertised to work 144-148 MHz/440-450Mh . Are you saying it works on 151 – 154 MHz and 462 MHz-467 MHz?
I bought something about 5 years ago all I remember it had 333 in the model number, it works fantastic on 144- 148 220 and 440 also its about 15 feet tall,weights almost nothing, but it works great I would recommend this antenna to anyone looking for an antenna in these frequency ranges
Comet CX-333
