New materal - uncutable ?
DXman
Yes, that's 3100 degrees F. Nine yrs of hard work.
Apr 5, 2005
1,732
1,204
173
76
West Coast - Washington
New material called 'Proteus' is reportedly the world's first uncuttable material
CT scan of test sample (masthead) after cutting attempts were made.
21-27 minutes
In context: Every substance we know of is cuttable, even the diamonds—until now. Engineers have developed a material they call "Proteus" that they claim is the first manufactured uncuttable material. The compound is made of porous aluminum and ceramic, so it is lighter than steel and yet will withstand any grinder.
Researchers at Durham University in England and Germany's Fraunhofer Institute claim that Proteus resists cutting by turning the cutting tools against themselves and dulling them. The material is made up of an aluminum matrix (aluminum foam) embedded with ceramic spheres. It is 15-percent less dense than steel making it ideal for applications like lightweight armor.
As the cutting tool bites into the aluminum, it suffers extreme vibrations when it hits the ceramic spheres. This resonance causes the tool to start bouncing, thus "dulling" its cutting edge. Furthermore, as the ceramic is hit, fine dust particles fill in the matrix. The interatomic forces between the grains increase proportionately to the amount of energy applied, making the material even harder the faster the tool spins.
"The force and energy of the disc or the drill is turned back on itself, and it is weakened and destroyed by its own attack," said Durham's Assistant Professor of Applied Mechanics Stefan Szyniszewski. "Essentially cutting our material is like cutting through a jelly filled with nuggets. If you get through the jelly, you hit the nuggets, and the material will vibrate in such a way that it destroys the cutting disc or drill bit."
Proteus is effective against angle grinders, drills, and other conventional cutting tools. It is even effective against high-pressure water jet cutters. In this instance, the material works differently in that the spheres' rounded surfaces disperse the water weakening the jet.
The researchers see possible applications in the safety and security sectors. Armored vehicles could be stronger and lighter, or locks could prove invulnerable to cutting tools. Ironically, it could also be used to make protective equipment for those who use cutting tools.
Proteus is currently patent-pending, and the team is seeking manufacturing partners to commercialize the material. If you are interested in the technical details, they have published their research in Scientific Reports.
Any machinist knows that if the cutter starts vibrating, then your RPM is too fast for your feed rate. The solution is to cut this stuff slow enough that the ceramic doesn't vibrate. Variable speed chop saw. Might take forever, but I bet it would work. Of course if you made a lock hasp with it, the bolt cutters will still get it.
I am hoping we see beer cans made out of this in the future. Headline- "Young man lobotomizes himself while attempting to crush Shlitz can on forehead."
Haven't had a Schlitz beer for a long time. Was talking about that the other day. Snack bar beside my barracks, sold 32 oz paper cups for 50 cents. Got hammered each night.
21-27 minutes
Key Word is They Clame It,s Uncutable Send It My Way My Naber Kid Can Cut It Faster than you can Go around the House Those Brats Will Tear Up A junk Yats
ANYTHING can be cut with the right application of high explosives. Of course if something can be made, it can be unmade with a slight increase of force over that which was used to make it, the laws of physics are not transmuteable.
Primer cord would cut it. It would not be pretty but you could do it.
I wonder if it has a resonant frequency that would cause it to disintegrate.
Its resonant frequency would be dependant on diameter and length. I dont recall the formula off the top of my head, but it is different for every solid at differing temperatures fyi glass is considered a liquid due to the way it flows over time
