Ok, here is an issue I am having with my linear amp. It is an old 9 tube base amp (a PAL 750B). Wattage is normal at 750-800 watts with 2 watt drive.
But recently, what is happening is that it is somehow causing frequency drift on my radio on SSB only. What is unusual is that the degree and consistency of the drift seems to depend on the tone of my voice and also where the mike gain is set. As I change the inflections in my voice it will cause this frequency drift to take place. The frequency always goes down, not up. The amount of drift from 27.385 for example would be to go down to as low as 27.3830 but generally no more than 27.3840.
Again it ONLY does it on SSB, not AM. It also is not dependent on band or antenna either so I believe it is a local problem with the amp or radio. It does not happen with the amp off or with my smaller 200 watt amp so I believe it is the large amp causing it.
The problem does seem to self correct for the most part after the amp warms up but does seem to reoccur.
Anybody have any ideas? Perhaps a problem with the power supply in the amp or the filter cap circuit? Let me know, and thanks!
