Older President Grant modulation limiter?
Ok all, Here is my question. I have an older President Grant that the modulation limiter has been removed. I need to find out exactly what type of component and value came in the radio originally so I can replace it. Can anyone tell me this information please. I would like to put it back. Thanks for your help I greatly appreciate it.
Take a look at the PLL chip on your Grant. Does it say D858? Or MB8719? Let me know which PLL chip it has, and then I can tell you what transistor it is. Thanks!
~Cheers~
Wow, fast reply. Thank you. It has the 8719. If you could also tell me the exact location on the board it would be very helpful. I had it written down but the paper with the information is missing. I am going to replace it and hopefully get this radio sounding as good as it did back in the day before some ass messed with it. I like nice clean clear audio and not a raspy splatter box. Thanks again for the super fast reply! ;)
Ok, the transistor number is TR24. It will be located in the front right part of the main board. The transistor that needs to go in there is a 2SC945. It'll just say C945 on the transistor.
I have the location of the transistor pointed out in the picture below.
~Cheers~
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
