Is it possible to spray paint a fiberglass antenna any color that you want on not hurt the performance of the antenna? Something like a wilson 5 foot fgt silverload with the cap on?
We built up a Cushcraft AR-10 10M antenna and painted it with camo colors - tan, brown, green, and a spot of black here and there. Hoisted the sucker up a tall tree, and it's invisible (which was the whole idea). At 50' high, you just can't see it. I would use a flat paint.Go for it. I lightly spray paint all of my antennas. Generally the base antennas. The white fiberglass or shiny aluminum stands out a mile away. I use the Krylon Ultra Flat Camo colors. Usually the olive drab. So painted the antenna blends right into the trees in the background and many times I've had to point the thing out to people they didn't even notice it and it's right on my roof. Does not affect performance at all. If it did, I wouldn't do it.
Yes it's OK...however it will fade...So then it would be ok to paint an A99 base antenna? Even the Chrome?
