PALOMAR ELITE 500 ???
nitroturbo4u
Feb 17, 2013
72
10
18
60
SOUTH EAST COAST S.C.
:whistle:Never seen one like this....It is at a estate sale....Has built in 12 volt power supply.
Has auto side band class ab1....Mint cond....
Lady wants 75.00 guarnteed to work.....What is power out on this???
Thanks all.(y)
Dude you need to run get that one for $ 75.00. That is a heck of a deal. Depending on the drive you put into it you should see 350 to 400 out. I would hit it with about a 2 watt dead key and let it swing. I wish I could come across a deal like that!!!! (y)(y)(y)
I bought a few of those in the 1990s when they first came out. They have a 35 amp built in power supply that you can also use to power radio and other things. Watch the back of it if your messing around because more than ones I was changing coax or moving things around and THERES NO FAN COVER OVER THE FAN ON THE BACK!! Needless to say it scares the $h!+ outta ya when your fingers hit the plastic fan blades LMAO!!
Also as mentioned makesure you watch your input drive or they will start distorting and scratching. I ran the ones I had at 10 - 12 watts and wouldnt push it past 15 watts input. The ones I had were running 4 x SD-1446 transistors but seen some of the others were running 4 x MRF-455. you will see about 350 watts on an average reading meter I never ran mine into a true active peak reading meter which isnt all that important anyways.
$75.00 is a great price if all works as it should take note that they are EXTREMELY HEAVY so watch where you set it up ;)
The later ones used 1446`s in them, the older ones MRF 455`s
I doubt it is class AB, they print that on all the Knock off Pal amps ( and Pal Elites and the Boomer 250 and 500`s.
Almost all of them are the vertical transformer style boards with auto SSB delay.
i was looking at a craigs list add in fla and figured id search the amp here first..they are using the exact pic thats on this forum and want 325.00 for it..
i guess they could have just borrowed the pic from here:whistle:
