Palomar RFX95HD
Try a 68 ohm or around that, usually they end up between 33 and 150 ohms. I do not like that swing mod myself, not much average swing and does not look good on the scope. The better mod uses a tip120 transistor a 220 ohm electrolytic a 100 okm resistor and a 5k to 10k potentiometer to set the dead key.
10-4 it's not in concrete yet so I can still modify and will consider your suggestion as well. Hopefully tomorrow I can have a little time with it.
Reactions: Enterprise312ok
Good deal Eldorado!
Ive honestly never measured the current across this resistor so i can't say for sure what is needed there.
everyone just uses 2 or 3 watt resistors there instead of measuring lol.
if you are concerned or the 1/4 watt resistor is getting hot when in TX, then you can parallel some other 1/4 watt resistors together in order to make a 1/2, 3/4, or 1 watt resistor etc.
four 150 ohm 1/4 watt resistors will give you around 37 ohms and will handle 1 watt.
there is no difference on the scope or in performance between the "add a fixed resistor to the bottom of the board" and the "use a tIP120 and a pot to provide a variable deadkey" versions of the mod.
I like to use the TIP120 method and mount a trimmer resistor inside the radio.
that way it can be set for wherever you want it but you don't have to worry about accidentally moving it by turning the wrong knob on the front of the radio.
Good deal Eldorado!
Well looking through the pile of pulls I found some half watt resistors which is what Bell's had used so it should be sufficient. The pulled stash saves the day.
After adjusting the modulation to where audio sounds good with no crunch I ended up with about 3.5 watt dk, 18 pep amp off. Amp on about 14 watt dk and will spike 100 before the limiter tames it to about 85-95 with voice peaks. Audio through headphones with monitor radio sounds pretty dog gone nice. I like it!
Thank you gentlemen one more time, I'll call it a success.
sure thing!
If you're looking to play a bit further with this, you can try replacing C71 with a 47uF cap, and see how that affects the AMC clamping.
And if you want to go even further, you can try strapping a 1K resistor across C71.
(you can play with this value a bit)
these mods change the timing of the AMC circuit and will allow you to tailor things a bit for your own radio and voice.
sure thing!
Thank you sir, I'll take those into consideration. I'm always up for more learning.
I won't have time until next weekend or so but will report back when the time comes.
Having Fun with RF....
Level 1 - Cooking with BIAS...
Today, we'll be using an ordinary Cobra 29 GTL/NW/ST/WX - LTD with the TA2003z Audio chip.​
As you know this radio was specifically designed to accept RFX75/85/95 - and the new 150 units - with optional Steel bracket bracing for your Ford Pinto (see Technical Service Bulletin TSB#1024: Explosive Results Caused By Arcing Of Your Lips Due To Poor RF Shielding Causing Severe Burns)​
Inside the Radio you'll notice that there are a lot of little parts connected to bigger parts and those bigger parts are connected to the metal case - this is where you begin your procedure...​
To prevent further injury - the Author has decided to SACK the entire idea...
In regards to BIAS - in an AM radio - there is no bias control - at least one that can be set readily (See AnyTone)
But you wouldn't need to either - you just need to remember to keep stock levels of power. The specs for that near the top of the instructions.
40 Watts PEP is a little different than a 4 watt carrier - one is a dynamic result of power being applied if only for audio peaks inside an envelope of other power it mixes in with. While another is a "STEADY" constant level of power being applied all the time for amplification through the device, aka - the lower, smaller figure of merit.
So throwing 40 watts pep in a tone all the time - like a elongated Roger Beep - can damage the unit.
But throwing a 4 watt carrier driven by even a M104 - when the limiters are kept in place - should prolong the life of the unit - considerably as long as cooling is provided.
Would that be The Mercedes-Benz M104 or The M104 Wolverine?
