I just discovered this.
The SO-239/ PL-259 connector on the back of virtually all CB's suffers from an impedance problem?
In the center of the connector the impedance is ~30-40 ohms.
Is this true at 26-30 MHz ?
How is this not ~equal to a SWR of ~1.6:1 before the signal even gets to the coax? (Simplified math)
Yes I know the definition of SWR involves the transmission line and connectors and antenna/load but impedance mismatches cause reflected signals where ever they happen right.
This has cause me to ponder a few things like:
Should performance seekers change the pl-259 type connectors on our 10-11 meter radios to N type connectors?
And:
Could this be why built in SWR meters are "notoriously inaccurate" ? Maybe they are just as or even more accurate than external SWR meters at least at measuring what the radio actually sees as it's SWR before the reflections of the 2-4 connectors required for an external SWR meter? (I know ... BLASPHEME !)
And:
