Please Help! Cobra 29 Receive Problem
Discussion in 'General CB Services Discussion' started by KGC-7375, Jul 14, 2015.
  1. KGC-7375
    KGC-7375
    Expand Collapse
    New Member
    Jun 20, 2015
    3
    Hey everyone. Recently my cobra 29 Ltd Soundtrackers Receive went out on me. There is absolutely no sound coming in from the airwaves on any channel. Another thing that suddenly happened at the same time the receive went out was my channel display goes blank when I switch the Bright/Dim Switch to Dim. The radio Transmits just fine though... Any help with this would be appreciated. Thanks
    Edit- This is not a mic/speaker problem. The needle on my S meter doesn't move at all like it should when receiving sound. The needle works exactly as it did when transmitting
    #1 KGC-7375, Jul 14, 2015
  2. BBB
    BBB
    Expand Collapse
    Jan 17, 2012
    729
    355
    Have you tried an external speaker to rule out the possibility of a blown speaker in the radio or tried a different known working mic? Those radios need a properly wired "Cobra" style 4 pin mic plugged into the radio to receive. It's not in PA mode right?
  3. KGC-7375
    KGC-7375
    Expand Collapse
    New Member
    Jun 20, 2015
    3
    Yes I know it has nothing to do with the speaker or mic. I have tested these and tried different mics. And yes it is is Cb mode not PA. I know it doesn't have to do with these either because the needle on the meter doesn't move at all like it should do with incoming sound.
  4. 9C1Driver
    9C1Driver
    Expand Collapse
    Aug 13, 2008
    2,924
    694
    If it's not a simple setting, speaker, or mic issue I would sell it in e-bay as a fix or repair. The Soundtracker radio's were probably the worst radio's Cobra ever had built to put their name on. They are not worth as much used so you would not want to sink a lot of money into it.
    222DBFL likes this.
Share This Page
