Polarization question
edfiero
74
43
Take your basic 4 element yagi.
It can be mounted Vertical or Horizontal for the desired polarization.
What do you get if antenna is mounted at a 45 degree angle, splitting the difference between vertical and horizontal?
Reactions: S&W357 and Tokin
Loose Cannon The one I had a Joe gun. Did 3db lower on rev ant trans at about 100 mils from a C B er we talk all the time I using my3 elmate flat side Beams SWR set 1.1.1 the same . on both
