Is there an adjustment for the meter. On full power when I key up the radio on AM the meter does not show full scale. Not even when I talk into the mic. On my external watt meter I'm getting full power. I wonder if it's a setting in the engineer menu.
I looked at both of mine just to see what they showed...I don’t normally do anything on AM.
One shows a S7 at carrier and swings full scale. The other shows S9 and swings full scale. Both show about the same on a wattmeter, about 10 watts peaking at 35-40.
You’re probably right about it being in the engineering menu.
