Pride DX300 screen light?
tfastlane
Jun 3, 2009
6
I have a Pride DX300 that works perfect, except the screen light doesn't work. Is it suppose to come on only when its keyed, or is it suppose to come on when the amp is turned on? Thanks ....... Tim
If, your amp is working perfectly, you should only see the Screen Overload Indicator come on when you are loading it up heavly or if there is a problem in the screen circuit.
If you suspect that the Screen Overload Indicator is not working properly (not lighting of even flickering) the the possibilities are the LED itself, R-35 (150 ohm @ 1/2 watt) or, D-28 (1N4001). Interconnecting wiring or connector failure could also stop the light from coming on.
If you choose to nose around in there, take ALL necessary safety precautions and then go at it.
Good Luck
