Programmable roger beep Echo Repeat Talkback
dss56
287
71
38
55
ECHO- ECHO REPEAT
PROGRAMMABLE ROGER BEEP
TALK BACK
DIRECTIONS
Roger Beep programmable Talk Back Echo Repeat
This is a keyup noise toy
Here is a newer version of the Roger beep this is programmable by you.
* PROGRAMMABLE ROGER BEEP-TALKBACK- ECHO REPEAT
** PROGRAM YOUR OWN SOUND BYTES/ROGER BEEPS
Ultimate *Programmable Roger Beep CB RADIO - Over 9999 Polyphonic MP3
This is a Roger Beep Module with Micro controller can download different Roger Beep sound MP3 files into TF card by yourself.
1.You can find one million MP3 audio file on WWW
2.You can used mp3DirectCut free software to cut your MP3.
3.Two Operation mode by toggle switches
First play first 0001.mp3
Cycle cycle play 0001.mp3,0002.mp3.....0255.mp3
4. 512mb TF card included. It will have 50 most common SB-Beeps with a list and #.
5.The Roger Beep sound stored in TF card.
6. Excellent sound quality
7. It's powered by 12v DC and draws about 250 mA.
8. The product comes with a 30 day warranty
MP3 Module: FT micro card info
1.TF card : 1GB - 32GB formatted with FAT32
2.MP3 Module read MP3
3.All audio files must be placed under -mp3 folder.
Audio file must be named 0001.mp3,0002.mp3.....0255.mp3 -4 letters not 2 or 3 letters .Audio file names can have any characters after 4 digits, such as 0001_Bruno_Mars_Count_On Me.mp3
4. You must format the TF card to make MP3 Module to play the music I specified.
5. To remove the SD Card just look on right side marked SD card. Use a flat head jewelers screwdriver or something flat you will see the sd card just push and it will pop out just pull out and put in a Micro Sd adapter Not included to program on your computer.
6. I recommend not making soundbytes longer than 20 seconds long. 20 seconds should be long enough its your choice.
7. Just google mp3Directcut free software and use to make your own sounds.
8. This works on 12vots dc.
9. To use on 5 and 6 pin radios just buy on Ebay the adapters from 4 pin to 5 or 6 pin mic’s and radios. You will need both ends the mic and radio end and should work fine.
Any questions please ask
Just go to youtube and put in >Roger Beep programmable Talk Back Echo Repeat
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
