Radial length
74IN
Feb 17, 2003
1,831
72
58
63
Labia
I have a spare Larsen 5/8 wave VHF mobile antenna I'm considering using as a base.
Will the radials still be 1/4 wave?
An alternative is that the radials should be at least as long as the radiating element. Huge difference in performance? Not really, but certainly can make a difference in matching. Since each situation is different, what ever works best, is best. Starting out with 'more' than needed is almost always easier than starting with less than is needed.
Sloping or flat; you decide. The matching network should take care of the match. If it was a quarter wave, you could approve the match by sloping the radials.
I think I'll try flat, I used sloping at about 40 degrees with a 19 1/4" antenna (1/4 wave), worked fine.
Thanks, all.
    BLACKOUT HF
    I am beginning the packing process...XENIA bound Going "Lite": this year....2 items for sale...Rig #1 = FT-920/Gud to Ex condition/Hand Mike/pwr cord/manual (NO BOX) ... #2 = My 1 owner FT-950....EX condition...Original Shipping Double Box/Factory Manual/Never used hand mike...Booths 9107-9111...Ya'al come by say hello...
    Incoming Region Produces X3 Solar Flare
    May 15, 2024 @ 14:55 UTC
    Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned
