Random Length Wire Antenna
Lazybones1222
Apr 6, 2005
948
Tampa Bay Florida
Is it possible to run coax out of the shack and then attach the center conductor to the random wire at a terminal?
I have a Dentron super tuner and want to string up a really long random wire, but my shack windows are a Florida style crank type aluminum, and would like to use coax to get just outside.
If so, would you ground the shield or just let it float?
How would I hook this sucker up? Any suggestions?
the method you are suggesting is the best way to keep rf out of the shack.
terminate the sheild to an outside ground and run the wire as long, high and clear of any obstacles as possible
You will also need a very good counterpoise, and the lower the frequency, the longer the counterpoise has to be (ideally in all directions, just like radials).
The tuner might help, but it can't do miracles.
As Beetle suggests, the shield needs to be connected to ground, but the ground needs to be more than just a ground rod. You need to bury some wire in the ground also.
Nope! Ain't gonna ask. Think I may still have the rags of that 'T'-shirt around here somewhere...
longwire
Hello radiofriend,
I do use a longwire of about 55 feet in combination with a CG-3000 tuner in the mast: this really works great! My FT-2000 runs OK
Good luck with your hobby and hoping to meet you on the frequency!
Greetings from Holland,
Jan
PD2JHP
