Ranger rci 2950dx
Discussion in 'Forum Help & Info' started by Gary Curtis, May 11, 2017.
  1. Gary Curtis
    Gary Curtis
    Expand Collapse
    New Member
    Mar 6, 2017
    5
    Can anyone help.have a ranger rci 2950dx. Doesn't seen to keep memory, have 10,11 and 12 meter band, when radio is turned off then back on again. I lose the 11 meter band and end up with only the 10 and 12 meter band.
    Any info would be helpful.
  2. undertaker
    undertaker
    Expand Collapse
    Undertaker
    Apr 5, 2006
    1,370
    272
    If it has a battery it could be that..
  3. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Professional Amateur
    Staff Member
    Apr 6, 2005
    13,921
    5,180
    No battery in the 2950DX models.
  4. w9cll
    w9cll
    Expand Collapse
    Jan 19, 2013
    2,720
    1,342
    Funny it reverts back to what it was designed for,
    338_MtRushmore likes this.
  5. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Staff Member
    Apr 6, 2005
    13,921
    5,180
    How old is the radio? It could be a bad memory retention capacitor. Do you also lose all preset memories? Also how is the mod done? Using just the jumper pins or does it have the E-chip installed on a short pigtail inside?
  6. Gary Curtis
    Gary Curtis
    Expand Collapse
    New Member
    Mar 6, 2017
    5
    Many thanks
    For getting back to me, it has the e chip installed. I think you might be right about the memory capacitor. I rang a friend who normally sees to my radios. And he thinks the same. Sounds like it will be a quick fix.
  7. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Staff Member
    Apr 6, 2005
    13,921
    5,180
    I forget which capacitor it is but Google should tell you. IIRC it is on the board behind the front panel but don't take my word on that.
  8. Gary Curtis
    Gary Curtis
    Expand Collapse
    New Member
    Mar 6, 2017
    5
    Hi
    Hope you can help on. This one, I have just fitted a 4dx cpu in to ranger rci 2950dx, everything is working button functions, but when mike is keyed or I start to modulate only have two of the bars lit up instead of all of them. What is causing this to happen. Any ideas on this
  9. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Staff Member
    Apr 6, 2005
    13,921
    5,180
    RF power setting either on the front panel or the internal adjustment pots is turned down. Either that or a final is blown or maybe it just needs an alignment. I would cgeck the power adjustments first. They are often dicked with to run it with an amp.
  10. Gary Curtis
    Gary Curtis
    Expand Collapse
    New Member
    Mar 6, 2017
    5
    Many thanks for all the help you gave.it was the internal pot,gave alittle turn while mike was keyed up on fm. Signal meter back to normal. Oh happy days.again many thanks, if I have trouble in future I know who to ask
    BBB likes this.
  11. Gary Curtis
    Gary Curtis
    Expand Collapse
    New Member
    Mar 6, 2017
    5
    Hi again,
    Just enquring what external signal meter would be compatible with the ranger rci 2950dx.
Share This Page
