rat shack trc 446
bigun297
Feb 14, 2007
42
pratt.ks
Anybody tell me the wiring code for the 6 pin on this radio?.Any help would be appreciated,have a guy that wants it for a backup radio,(dont know why!)but to each his own.Thnx bigun :?
6 pin plug?
I would expect to see a DIN plug on it...
Did the origonal mic that came with it have "up / down" buttons on it or any other controls?
If this is just a cb I can't see any reason why it would need more than 5 pins unless it had some other control functions.
Your CB has these features:
NOAA 7-Channel WX Band - lets you tune to seven national
weather Receiver service frequencies which provide local weather conditions and forecasts.
X/Alert Indicator - shows the CB is ready to receive and
indicates the reception of a weather alert.
Built-In SWR Meter - helps you tune your antenna system to
optimize your CB's performance.
RF Gain Control - lets you adjust reception to match the
strength of the received signal.
Convenient On-Microphone - lets you quickly scan the band for Channel Up/Down Controls communications.
CH-9/NOR/CH-19 Switch - lets you quickly tune to emergency Channel 9 or Channel 19 without using the rotary tuning control.
Screw-On Microphone - ensures rugged operation and long life Connector
PLL (Phase-Locked Loop) - uses a precise frequency reference crystal Frequency Synthesizer to provide reliable and exact tuning.
Two Ceramic Filters - provides superior channel selectivity and
prevents adjacent-channel interference.
Specialized Squelch Circuit - compensates for fading signals and
eliminates signal chopping during reception.
Last-Channel Memory - tunes to the last selected channel each time you turn on the radio.
Lighted SWR/RF/Signal Meter - displays the signal strength and the standing wave ratio (SWR).
Digital Channel Display - makes the selected channel easy to see.
Noise Blanking - reduces the noise occasionally generated by
nearby electrical motors or automotive ignition systems.
CB/WX/PA Switch - lets you quickly select among normal CB
operation, weather mode, or public address mode.
RX/TX Indicator - shows whether the CB is transmitting or
receiving.
S/RF/SWR/CAL Switch - lets you quickly change the display of the RF/Signal Meter to show radio input/output
signal strength, the standing wave ration of
the antenna, or SWR calibration data.
I wouldn't say this is a bad radio :)
made in early 1999.
6 pin plug
Bushwack i dont know why it did'nt come with the din plug!.BUT! the radio was givin to him and he was wanting me to wire his 4-pin cobra mike to this mess,i think he ought to call rat shack and try to get the original mike that was supposed to come with it. bigun297 :D
the radio shack 446 DOES NOT HAVE THAT STUPID PUSH IN DIN PLUG. 1 audio (white)---- 2 recieve (black)---- 3 transmit (red)---- 5 (shield)---- 4 and 6 (NC not used)
Yah Im guessing Radio Shack pulled there heads outta there asses and put a real mic socket on that radio.
trc 446
I got it fellas,pain in the ass but you really need to have jumper wires when you go from 4-pin cobra mike to 6-pin rat shack radio.Thnx for ya'lls hep! bigun 8) p.s yes bushwacker it came with the mike that had the up/down buttons and lock,but the old boy that brought it to me could'nt find it and ratshack disconntinued it's production.So we'll ya'll know the story! can ya fix it? :shock:
