Reapeter Offline?? Need help locating.
hotvette101
New Member
Aug 16, 2013
6
MICHIGAN
Is there anyway to check on a repeater, this repeater is walking distance from my home, but according to google maps, its in the middle of a swamp. I ll give your the information ..
Auburn Hills
145.130- K8DXA
444.2625+ K8DXA
Ummm.....well if it's that close you could try transmitting into it on the proper frequency with the proper offset and proper CTCSS tone if required and see if you can hear a carrier from it when you unkey.A handheld on low power would probably work since it's that close.
Mmmm
Tried keying up, no response (no voice) ... Can't use yet, because studying for my Tech exam, no call sign yet, but an avid listener - :oops: Anyone in Pontiac Michigan area can help ?
