I decided to pull out the old ham gear and give it a go.
I'm using an Icom IC-710 rig on 80 - 10m on a random wire antenna with an MFJ tuner (the lesser 300W one). The rig is powered from a 25A switching supply. I ran a braid strap from the chassis of the power supply and radio. The power supply is DC grounded via its AC supply from a 3-wire cord.
The feed/antenna is about 20 feet of RG59U coax with a bannana plug soldered to the center conductor. The bannanna plug is stuck into the random wire port on my MFJ tuner. The coax braid is not connected to anything. This coax basically runs straight back to the shack wall and outside through a hole and is then soldered to the end of a bare, copper clad wire 132 feet long that is streatched between two trees with a piece of nylon rope at each end.
Since the coax shield is not used, I didn't care about it touching the shack wall and it just hangs from the hole in the wall to where it is soldered to the antenna, about 10 feet up at that point. The other end of the antenna is about 30 feet up.
Now, I tune up 80 meters while sending CQ. I'm only running about 10W and I get the reflect down to 0 as indicated on the cross needle meter on the tuner.
All seemed good, but I noticed that I feld some burning on my hand where it was lightly touching my radio as I was tuning the antenna capacitance knob on the tuner. I also caught a glimpse of my analog multi-meter, set to AC volts with the leads just sitting on the bench next to the radio, and it registered up to maybe 3 Volts. Also, my spectrum analyzer sitting on the bench was centered on the band with a 2-meter rubber duck antenna connected and it was showing -15 dBm of signal.
Now, I was looking at an online RF safety calculator and it is indicating that even at 100W into a dipole, you only need to be about 2 feet away, but it just seems wrong to see my multimeter swinging around.
I also noted that the radiated signal was much less (about -40 dBm) outside where the coax is soldered to the antenna. (not that I realize that the coax is also part of the antenna here, I'm just mentioning it because it's there).
