Thanks Rob, that's pretty badass. What do you use to align a receiver? I wonder if that tone generator on the website is any good or if the sinad meter is any good? Thanks
It requires an RF Signal Generator; the most expensive piece of gear by far. Usually $300/used - or more.Thanks Rob, that's pretty badass. What do you use to align a receiver? I wonder if that tone generator on the website is any good or if the sinad meter is any good? Thanks
Yeah 10-4, it says for the new cobra 29 ltd alignment procedure to adjust l2-l9 for maximum signal on af voltmeter though... any thoughts or ideas??It requires an RF Signal Generator; the most expensive piece of gear by far. Usually $300/used - or more.
Tuning/aligning receive in radios is not only the most expensive - equipment-wise - part of radio work, it is also the most time consuming and difficult. A high-end RF signal generator is essential and unavoidable to the process. If the radio doesn't need to have the receiver tuned up, so much the better. The voltmeter isn't nearly as essential as a SINAD meter - which accomplishes the same thing as well as making sure that the signal isn't distorted from over-peaking - which is something that the voltmeter cannot detect.
I use that SINAD program and a Hp signal generator - which I was fortunate to find for $250.
Yeah bought a hp 8640. I'm just trying to figure everything out. Different radios call for different test equitment so I'm just trying to put all the pieces together and see what I need and what i don't really need. It's a little confusing, so I appreciate everybody's input. ThanksTuning/aligning receive in radios is not only the most expensive - equipment-wise - part of radio work, it is also the most time consuming and difficult. A high-end RF signal generator is essential and unavoidable to the process. If the radio doesn't need to have the receiver tuned up, so much the better. The voltmeter isn't nearly as essential as a SINAD meter - which accomplishes the same thing as well as making sure that the signal isn't distorted from over-peaking - which is something that the voltmeter cannot detect.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
