provided the internal power supply would handle the extra amperage drawn by the RFX75 I'd say it would work good.
Problem is, most cb base stations have a power supply that's barely capable of running the rig after a standard tune up let alone adding a replacement final section.. If you beefed up the power supply you would be able to run one.
