ROHN Allowable vs. Effective table help?
CB590
W9WDX Member
Jun 29, 2016
1,545
1,263
173
Trenton Nj
www.590dx.com
What's the difference? Confused here.
Rohn 25G 30'. Table says 1.7, other says 7.9 sq ft. Both say 90mph.. I'm looking at Gizmotchy with 5.7 sq ft
What is your question in particular? From what the charts tell me at 90 mph for three seconds at 30 feet your maximum Square footage should be no more than 1.7 SqFt. in chart number one.
Chart #1 is a Designer's safety margin to over design the installation.
Chart # 2 is a actual performance guide. It is what you can truly can expect to be the maximum.
Commercial Liability for a defective design is very expensive if it falls down on the public. Liability is one of the considerations for an engineer for maximum safety and longevity of the project.
I'm trying to figure which chart to use based on my 5.7 sq ft. Proposed beam..
I'm thinking ROHN 45 at 30' and 80 mph then based on what your saying.
Though undertaker is saying the other chart and good with Rohn 25..
I probably should not got into this thread, I Diesel design everything.
(Humor) I designed an aircraft could taxi like crazy, turn on a dime, zero to 500 mph in less than four seconds, but was too heavy to fly. If I spent money on a tower, rotator, and a beam antenna I want it to stay up there forever. I personally go with the 45G at 40 feet.
But remember I over do design.
I wanted to know which chart I should go by.. but I get it.. the 45G would be better for longevity. The issue would be the $300-350 price increase over the 25G.. with the $250-350 I could buy the tilt base plate though..
I would use the second chart for the 45G. I look at it this way, The antenna cost good money, the rotator cost good money, the coaxial cost money. If the 45G survives 2 or 3 storms that the 25 might fall down it has paid for itself. JMHO.
3star has the 45G for $904 and $170 freight.. not bad.. the 25G is $530 and $170 shipping.. $370 difference.. hmm
What is the cost of the rotator, antenna, and coax?
Is this is the one you are buying? $150.00 from ebay
shopping
I would also recommend 45..if financially possible. Having climbed both, there is definitely a noticeable difference in stability when you're on them. I have 48ft of 45g and with 2 guys working at the top it moves less than 1 guy on top 40-50 ft of 25.
One other thing to keep in mind with regard to cost. The 45 requires a larger base. So you're looking at spending more on concrete.
I agree. I usually stay away from these too except for recommending proper guying lengths and heights and maybe what type of base of put in. Personally I myself will NEVER use a guyed tower of any sort but that is just me. I have several antennas to mount on the same structure and getting them up and down a tower with guys is a royal PITA. With my free standing tower it is a piece of cake with no guys in the way. Raising a multi-element HF yagi with guys is just too hard unless you have the ca$h to spring for a crane. I had a crane truck install my 64 foot Trylon Titan in one piece and that was expen$ive enough at $150/hr with a two hr. minimum. I also tend to over-engineer things. All my antennas come with the standard mounting brackets for a 2.0 inch OD mast. I upgraded to a 2.0 inch ID mast which is about 2 3/8 inch OD. Not that much difference but the wall is thicker and it means changing out all the brackets on most of my antennas. I also threw away the 1/4 inch U-bolts that came with them and upgraded to stainless steel 5/16 hardware. If the antenna already has 5/16 hardware I upgrade to 3/8. I just do this out of the box.....why wait for an ice storm to point out what I should have done before. I also reinforce the boom and elements where brackets attach to keep the tubing from deforming and to allow greater clamping pressure. Antenna manufacturers build for the average installation. Here on the east coast where we can get heavy ice conditions and a nor'easter of near hurricane strength together I tend to err on the side of caution or as we like to say on the side of common sense.
