Rotatable co-phased 10m/11m base antenna
KF5FUR
Mar 28, 2010
67
40
Republic of Texas
The antennas are separated by 10ft 4in. With about 6ft of harness left over from the center bracket. The setup may dance around a bit in the wind, but not as much that it will degrade operation. I used two aluminum pool dome poles one with a "male" end that slides into the other with two "female" ends, I placed the angle bracket so that it would clamp the joint and simply mounted the antenna on either side and there ya go.
Sorry about the picture quality, I had to crop them, as my camera takes 1200X1300 pixel photos and I had lack of good places to take the pic since I could not undo the bolt on top of the vertical piece that mounts onto the angle bracket.
Post more later when I get it installed on roof
  • @ Mark Malcomb:
  • @ Naysayer:
    I’m
  • @ kingmudduck:
