A friend has a no-name 4-pill in a bright blue case...Class AB, 4x1446s...has a printed circuit board. Hooked up to a Uniden 78, running mini-8 coax into a roof-mounted Wilson 1000.
When he flips the amp on (just turns it on) the RX signal drops and sometimes slowly builds back up (like something in the amp is charging?) sometime it doesn't come back. If we turn the radio off for a few seconds, then back on; the RX levels return to normal. If you toggle the amp on/off a few times, you can literally eliminate ALL the background noise to zero. Turn the radio off/on, and things return to normal (regardless if the amp is on or off).
We've tried toying with the ANL/NB switch, looked everything over, switched antennas (used my W5000 in place of his W1000). We even went as far as swapping in my 2-pill and the 2-pill doesn't do it (class C). The only thing that works is to turn the radio off for a few seconds...
Is this characteristic of a Class AB amp? Or should we have it looked at? I don't know what make it is...looks fairly clean inside. Other than this annoyance, the amp works well...I was almost wondering if it was the relay??
