Sirio Turbo 5000pl
Discussion in 'Product Reviews' started by Cpt shakes, Mar 17, 2017.
  1. Cpt shakes
    Cpt shakes
    Expand Collapse
    Jul 1, 2015
    38
    17
    Other operators and myself included have done swap out comparisons with the Wilson 1000 and the Serio turbo 5000 PL out performs the Wilson both in receive and transmit. And it screwed right onto my original Wilson magnetic mount. And yes, it stays put.
    222DBFL likes this.
  2. 222DBFL
    222DBFL
    Expand Collapse
    Jul 28, 2013
    3,301
    1,278
    Yep. I found the same with my Sirio PL5000 magnet mount antenna versus both the K40 and the Wilson 5000. Better RX and TX range. All that I didn't really care for was the RG58 coax that comes with the Sirio magnet mount, the PL145. I just switched mine out to Andrew LMR240. Worked very well and was easy to install on the magnet mount as well. Some good RG8X would work just as welll I am sure. But when you have a lot of LMR240 coax laying around, might as well use it!!
    Anyways, I did find that the Sirio performer 5000 did a better job then the Wilson 5000. For that matter, the Turbo 5000 and the 4000 model as well with the long whip, all 3 antennas worked very well for both local and DX comms.
    I even modded one of the older Sirio 5000 antennas. Drilled out the hole for the whip and cut a 102" whip down. Made one stiff antenna. Stayed straight at highway speeds no problem! But it wa heavy! They now make the whips a tad smaller in diameter than they used too. 3.5mm vs 4mm I think if memory serves me right. And the older ones with the larger diameter whip did work a little better for highway use IMO.
    None the less, one of the best antennas I have used besides a 102" whip or a large coil type antenna that was almost 8ft tall, (old MM Big Jon?). At any rate, they are good antennas for what they are and do a good job no doubt!!!
    The Mad Scientist and binrat like this.
  3. The Mad Scientist
    The Mad Scientist
    Expand Collapse
    Apr 24, 2012
    761
    97
    I used to use the P5000 and I agree that it is the bast mobile antenna that I have used to date.
    binrat and 222DBFL like this.
Share This Page
