Sonar G, need shematic with wiring for DC power cord
Image below should be clickable. It's a scan of the Sams page with the 120 VAC and 12 VDC plug wiring. Sams CB-6 if you want to pick up a copy of your own.
I guess looking at the rest of the schematic and the power plug on the radio it does show pin 7 is ground so that means pin 7 will be positive...Thanks, Adam
Glad you figured that out. I just happened to run into a reference for the right Sams, and there it was. I've never seen one of these in the real world.
