Starting a new yagi today
Oh, that was the Coors Lite ground plane!
I found that I left the beam set at 40 degrees most of the time since EU is my main interest. Not sure whether I'll do another rotary beam for 20 without a tower. I'm considering a switched 2 element vertical array- either Christman phased or a simpler switched reversible yagi or delta loop array. Not sure yet, depends on how much time I'll have for radio and what I can do with the space I have in the backyard-- staying away from powerlines and my 80/40 dipole.
The end fed half wave vertical may be put back up in the meantime since it performed well, I have some poly dielectric coax to make a new tuning cap, and the cost would be zero.
I'm sure you'll figure it out. I keep revisiting the idea of a rotatable beam, but like you, I seem to hesitate.
Perhaps you can share this tuning cap info with me. Specs on everything . . .
I would be interested.
Homer
Sure-- here's the one I used originally, you probably remember this thread:
http://www.worldwidedx.com/amateur-radio-antennas/33237-end-fed-1-2-wave-vertical.html
This is a good website that has several examples of L/C parallel circuits to match 50 ohms to high Z feedpoints:
Bobtail Tuning Network Design
I think I mentioned it in my thread (it's been a while), but the foam dielectric couldn't handle the RF voltage with the amp. I've also used coax capacitors in gamma matches, they work great provided you don't use foam coax!
Rick
