I think the answer to my problem is lack of chassis grounds...
I have static in my receive, a lot of it, as in around 7 S-units. I figured it was from a cellphone charger and XM receiver (unplug either one and it subsided). However, I can also simply place my hand on the radio and the noise decreases.
The radio is a HongKong 29 (similar to a Philippines), the setup is a 29/2-pill/Wilson 1000. The only grounds either the 29 or the 2-pill have are through their respective power leads (the radio is mounted to a plastic console, and the 2-pill is sitting on the floor). The 1000 has an added ground wire from the magnet's bolt to the vehicle's body. It does this regardless of whether the 2-pill is hooked up or not, so the amp is not likely the issue.
I'm figuring that since the chassis isn't ground well, the case isn't blocking errant RF? And by touching it, I'm closing the "ground" circuit?
Does this sound plausible?
