Found it thank you.. Tommorows little project ..If you just go through this thread you will find everything you need to know.
Removing limiters is never a good idea. It does in fact turn a radio into a splatter box. You go ahead and believe what you need to so you can feel right. Any tech worth a darn can get the Ronald to sound good without cutting it up. Nuff said.Removing modulation limiters do not always distort every radio theyre removed from somtimes the removal brings a radio to life like the president ronald
Not looking into remove limiters buy just open up the audio na little more.. I'm using a Mic with adjustable compression.. No spatter box's. Just want decent loud clean but not over driven audio .. Never had problem Comunicating local or skip weather in US the US or Australia .. Never ran.power either..Removing limiters is never a good idea. It does in fact turn a radio into a splatter box. You go ahead and believe what you need to so you can feel right. Any tech worth a darn can get the Ronald to sound good without cutting it up. Nuff said.
Did you ever figure out what W3 was for ?Here's a picture of the adjustment pots. I wonder what W3 does. Anyone know?
