Submit your Comments With Others on FCC NPRM 10-106 (Part 95 Services)
AudioShockwav
Extraterrestrial
Staff member
Apr 6, 2005
9,033
8,811
593
Nor Cal Sierra Nevada
If you are a licensed GMRS user, Here is a Survey that myGMRS.com is doing so you can add Your Comments to the FCC on the Proposed Rule Changes.
From myGMRS.com::
The FCC has released a Notice of Proposed Rule Making which directly affects all GMRS licensees.
Comments are being heard by the FCC until July 1, 2010. Please consider responding using the methods described in the NPRM document.
myGMRS.com will be responding to the FCC as well, and would like to hear your suggestions. A survey has been created where you can have your suggestions included.
Regardless, we urge you to submit your own separate response to be sure the FCC reads and counts your comment. Being included in our response is no guarantee that your comments will be seen.
Here Is a Link to the survey
myGMRS.com - GMRS Repeater Directory
