Surgeon needed for RM Italy KL503HD
Maybe this is the part that is disconnected. ATT 1 7dB. If so then I'll do more digging to work out what it looks like when it is properly connected.
All of your input power runs though it, even in the high position so it has to be able to handle ~35W without getting destroyed. It attenuates your input by 7dB.
  • A0700-40-3X.pdf
I think the Q5n2 will be ok with the driver bypassed, maybe someone who has done the modification can verify.
@TimmyTheTorch
Here is some 503HD info you might find helpful. Ask some of these posters. This should get you started.
Good Luck!
P.S. if you are going to bypass the driver, don't Snip things. Unsolder and lift/remove. You already have the C.B. removed from the amp.
Thank you for the PDF. It's very helpful.
I sure must like making things more difficult for myself.
The replacement mosfets arrived today. Time to install them.
When soldering in the new ones, is it better to solder from the top side of the board or the bottom side? The top side has a lot of stuff in the way of reaching where the leg goes through the board. The bottom side has better access to the three legs. I know there will be some excess leg material I will have to trim regardless. My current plan is to solder from the bottom side as shown in the second picture.
View attachment 62445View attachment 62446
You'd be best from the bottom so you can trim the what sticks out too far. For assurance, I like to see the solder flow all the way through to the other side.
Reactions: TimmyTheTorch
I definitely need more practice soldering. I am currently finding it next to impossible with my current technique and skill level to get all of the old solder out of the three holes the mosfet legs feed through. I've been using a solder wick and solder sucker in the attempts but no joy. I even did the "add solder to remove solder" approach too but no. I then decided to deal with it when inserting the new mosfets. I just hope I did not bleep up any traces on the board whilst trying to remove the excess solder. If I did, well, that's a lesson learned.
Please tell me this is NOT how you soldered in the replacements...
If so, STOP! DO NOT TURN ON THE AMP.
The Mosfets are backwards. They should be soldered on the UNDERSIDE of the circuit board - just like they came out.
The Mosfet "tab" is what goes down against the "thermal pads" on the aluminum heatsink. The legs stick UP through the 3 holes. No thermal grease is needed on the Mosfets.
I highly recommend using flux cored eutectic solder. Kester 44 has a 3.3% type 44 flux core and the flux is "active". It may leave a slight non-conductive "residue". IMHO, this is the best all around solder. For oxidized solder or copper, the 44 flux has superior wetting. The residue, if any, can be cleaned with alcohol.
Amazon product ASIN B0149K4JTY
You can also use a "no clean" type of flux cored eutectic solder that has a 1.1% type 245 flux that leaves no residue. It has a "mildly active" flux. This will work fine on any non oxidized connection.
Amazon product ASIN B00068IJOU
Spare your self the angst, frustration, burned up traces, and transistors and DON'T use a NO Lead solder.
P.S. Also, you didn't mention if you are going to bypass the driver or not. If not, then the 7dB part is correct.
If you are going to bypass the driver then the 7dB part is not correct. You would use a 3dB 40w part.
  • A0300-40-3X.pdf
No soldering has been done yet. Seems we have some new folks in our support area that are not quite up-to-speed on how to handle after-hours production outage alerts. Fun evening!
This is the Kester 44 solder I got the other day when I also got the recommended solder sucker.
For now I decided not to bypass the driver. I decided if I bypass the driver at the same time as I replace the mosfets (especially with being a newbie at this stuff), I would have less idea on what was wrong in the event it did not work properly. The 7 dB attenuator was ordered on Monday, not sure yet when it will arrive.
I won't be using my Anytone AT-5555N II with this amp when I am done so it should have a safer life.
And thank you again for all of the information. I am glad you do not assume that I will do the stuff correctly. I did take some pictures of the innards before I started but missed some areas.
I got up this morning to find a note on the dishwasher that it won't run and a plugged sink in my youngest daughter's bathroom. Long hair and makeup products do wonders for a teenage girl's living environment. Beats being bored!
Using the solder sucker I mentioned earlier.
The trick is to use a conical or small chisel soldering iron tip (minimum 700F) and come in at a 10~20 degree angle from horizontal and once the solder turns to liquid (less than 1 sec), LEAVE it there.
Then with your other hand place the solder sucker straight down on the through hole and the soldering iron tip. The Silicone tubing will form an airtight seal around the tip and the PCB surface and then push the button (1 sec).
Total time = <2 seconds and you won't burn up the trace or damage the component.
I spent a lot of time jacking around with a pointed tip that I think I bleeped up a few of the pads. By the time I changed to a chisel tip and learned the "add solder to remove solder" tip, I was nearly done. The surface scratches are from my first attempt at pulling the mosfets when using the pointed tip to melt the solder. FAIL. If I killed the board, so be it. I've learned a lot from the folks here during the short time I've been a member and learned a lot about what not to do. A few lessons may prove more costly than others. I even bent my wife's favorite tweezers. That's not good! But, onward and upward.
My Dad spent nearly 50 hard years as a sheet metal / iron worker and I sure could have used him around again for the 1000th time since he passed. First he'd have busted my balls for what I did with such a tiny soldering iron, then he'd grab us a few cold ones and the teaching would start.
After the cleanup here's what I am left with. I doubt I'll be able to work on this again until Monday night. Who knows, this may end up posted as an amp for parts listing but I really do hope I can fix my own bleep-ups and get this working again. I am a proud member of the "Tubthumper Society"... I may get knocked down but I get up again. Also a good approach when growing up playing hockey for 25 years or so.
Maybe this should be a sticky with a "Cautionary Tale" tag. :)
A learning experience but not all hope is lost there my friend. See those pads you pulled off, they can still be flowed from the other side with a little patience. No it won't be pretty but can still work. Pads that need to be soldered on the side you're showing us still have enough foil to flow onto.
Just a thought.
