M
Mudbug101
Guest
After rigging up my radio a couple of different ways to get more power, I found a flaw in the slaw and don't know which is correct. After purchasing this mod, the instruction here says to put the modulator (2nd item from right) the negative leg to the rear of the radio BUT this other guy says on his forum to put the negative leg away from the final. Which is it? I believe the guy in the forum more because I tried it the other way and it doesn't seem to work so his way must be correct. I am installing this on a Cobra 29 LTD.
Here's the links:
The Swing Kit: http://tinyurl.com/a985y
The Forum: http://www.radiomods.co.nz/forum/viewtopic.php?t=131&highlight=cobra
Who's correct??
Here's the links:
Who's correct??
