Tektronix 453 Oscilloscope, replacement probes?
office888
499
17
35
Hartford, MI
I'm looking at buying a working Tektronix 453 oscilloscope.
No probes included though.
What would you gentlemen suggest as an inexpensive replacement? (Less than $50 shipped ideally) I know you can get a Chinese 10x probe for $10, but I'm a little leery about the quality.
They would probably work.
I would be concerned about using them for high voltage though.
Not that they aren't capable; just leery of working with high voltage.
I won't be poking around HV a lot. This will mainly be used for monitoring my station output along with a frequency counter.
However, I may use it on occasion to ensure caps are working as they should, and ensuring AC ripple is kept to a minimum. Heck, it may even see some work outside to monitor fuel injectors!
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
