I can't ask this question over at QRZ.com cause my flame suit is old and wouldn't withstand the heat.
I do not have much experience with these types of solid state amps.
I understand that the 350HD has a key jack on the rear and that the delay button will reduce power for different break-in rates.
My question is: When these are modified for 11 meters, do all of these features stay the same or does the modification process change things? As in, does the key jack still work along with the delay button.
I have a 2950DX that I really enjoy using. It is bone stock and when checked today it was showing 2.5 watts DK on low and 10 Watts on High. SSB looked like 15 watts on low and close to 30 watts on high. My meter only reads RMS and these results were obtained with a high tech whistle.
Has anyone ever used one of these on CW and if so, what was your results?
Also, is the input circuit tuned decent or is it "hit or miss" with each unit?
Is there any other amp that may work as good or better (within the same price range) that I should look at. I want the best sounding SSB signal also.
Thanks.
Thanks.
