Trying to help a friend (Palomar amp issue)
guitar_199
Mar 8, 2011
911
1,181
153
Deer Park, TX
The model we are talking about is the Palomar DX200B.
The problem.... right above the LOW/MED/HIGH switch is a little board with a resistor that has 8 and 2 as the first bands.
A cap shorted an smoked that resistor and it LITERALLY burned the multiplier band OFF to where you can't read it. It is gone!!!!
I can't find information anywhere on this thing. I did find one "link" that said it had it..... and literally wound up looking at a pic my wife wouldn't like!!!!! :O
If anybody has any info or better yet.... actually has one.... I'd sure appreciate a hand.
I know that the first two are Grey-Red so it is 82 ohm, 820 ohm, 8.2K, 82K, 820K, 8.2M????????
Thanks!
Bob
Thanks!
Bob
Measure it....it may offer a clue even when burned.
It's a 50-ohm circuit where these resistors live, so my money is on eighty-two ohms.
All the other choices are way too much higher resistance than 50 ohms to be likely.
A value of 8.2 ohms would be too small to make much of a high/low difference.
Can you post a picture of the board?
If it is a PI attenuator, having an 8.2Ω series resistor with 580Ω shunt resistors will get you about 1.5dB attenuation with 50Ω in and out. I don't think the 8.2Ω should be ruled out quite yet. But I am just guessing its a Pi attenator...
Edit: For a high-med-low (three steps) arrangement, 1.5dB makes sense as that represents a 30% reduction of the signal.
Reactions: walterjn
