TS-590 AM Broadcast Mod.
Mudfoot
Elmer
Jun 17, 2009
10,928
6,299
698
63
Southeast Ohio
Has anyone done this to their 590? I pulled the case and gandered, there are 2 pins without a shorting jumper. I assume I just need to find a jumper and short the pins.
Supposedly, signals are still attenuated above and below the broadcast portion. I like to listen to a few AM stations, mostly WLW, but not much info on the mod is to be found.
It says it has a local/distance switch. All I see is 2 pins without any jumper.
http://www.mods.dk/view.php?ArticleId=4684
Remove indicated jumper for the modification. Says nothing about the other pins so don't mess with them.
Well, I guess add a jumper and see what happens. I don't usually listen to broadcast stuff on my radio so don't really see a need for it. The 'flip-side' of that is that the broadcast frequency ranges are usually attenuated to keep them from interfering or affecting the other frequencies near them (or harmonics). Whatever 'floats your boat'?
The author of that mod is an Italian station. Maybe the 590 has a european version, I dunno.
I found the same frustration, when I was going to mod my radio. I don't know how similar our radio situations are, but the pictures displayed, of my radio, were the European version. Of course, it looked different, when I split the cases.
Good luck......
Good luck......
Hihi OMG me too ! Jk.
Well get R done !
Sent from my DROIDX using Tapatalk 2
Good luck......
Well get R done !
It's done
here's the link......
http://www.worldwidedx.com/icom/58693-icom-ic-2820h-extended-transmit-modification-usa-models.html
