when an amps tuned up on antenna A then switched to antenna B should your amplifier be returned to antenna B?
I've read so many postings suggesting that one should tune their amplifier using a dummy load.
Then remove the dummy load and hook your stations antenna up.
Wouldn't this most likely put the amp out of resonance as the antenas readings (swr/ref power) will differ from the readings you original tuned the amp to while using a dummy load?
Or is it just the transmitted power input to the amp that puts an amplifier in resonance?
And changing from dummy load to antenna or antenna A to B will not or should not change the amps resonance?
Another nutty question from Stella. Thanks.
