Got it thank you .. Have a great dayBetween the two of these, you should be able to figure it out.
Good Luck.
Tried different elements no change.. When I do the condenser I get audio but not strong as it should be.. I had a transistor 2n3219 with a broken leg and the 47k risistor was cracked.. I repaces both it with parts but no change something else down the line might have gone bad. Got to dig deeper .. Thank.For the replySounds like the mic element is bad. I have several with the same condition. Hook a oscilloscope across the element connections and see if you have a signal when you talk into it, or even scratch across the front of the mic.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
