understanding the A99,, the 1/2 wave over 1/4 wave bit
davev8
Gold Star/Marvin Award Member
Apr 26, 2011
164
42
38
59
east cost lincolnshire England
Solarcon say the "A99 is a half wave over a quarter wave variable mutual transductance tuned antenna"
i understand the variable mutual transductance bit,, that will be the tuning rings over the inductors i know its not a 1/2 wave physically over a real 1/4 wave as it will make it 9feet longer for 10/11m ..so its ether BS/marketing speak or what i suspect the matching network makes it think its over a 1/4wave ..what i whuld like to know is how is that achieved and what are the pros and cons of this type of matching network for folk not familia i will put a schematic and a photo (credit Tech 833)
A lot of assumptions are made in this post for the sake of simplicity of Schematics to working value and ranges to work with - so no flames needed - just trying to open up a discussion with a ball that has been hit so hard it's missing half it's cover - don't ask about what is still left for the rest of the playfield to work with...just open dialogue helps.
Well, need a better photo - but from what I see you've got, is the Loading for a 1/4 wave ACROSS the 1/2 wave - with it's own loading coil. So between the winds, which needs a better photo to count those winds - the ƛ -1/4 wave provides a working impedance for the ƛ- 1/2 Wave to Parallel against - like two coils with one tuned with a capacitor and an air gap to change the "reluctance" coupling the 1/4 wave loading and the 1/2 wave loading - together into one package.
I can see the Red coil winds are possibly that 1/4 wave - but the "capacitor" to load the 1/2 wave element must be located around those tuning rings, this cap / sleeve combo provides an Air Gap for the coil load (your 1/2 wave) and Capacitor so the tuning rings work as the "slug" for the tuning - the 1/4 wave just "loads" the matching network to offset the impedance mis-match of the 1/2 wave being much higher than 50 ohms - so more than likely it's a 1/4 wave or 72 ohm inductive impedance load - parallel with a ~1kOhm 1/2 wave whip tuned to offset the impedance so the 72 ohm and the ~1kOhm 1/2 wave - matches close to 50 ohms...per your schematic...
Xr = 1/(1/R1 + 1/R2)
So 72 ohm (expected from 1/4 W/L Dipole Impedance = 72 ohms and the tuning range of the 1/2 W/L with tuned impedance ~1kOhm....
Solving for 1/4 W/L = 72 or 1/72 = 0.01389
Solving for 1/2 W/L = 1,000 = 1/1000 = 0.001
So = 0.01389 + 0.001 = 0.01489 or 1/0.01489 = 67.2 ohms ...
So the 1/2 W/L (ƛ) expected of 1K ohm and 72 ohm of a dipole 1/4 w/l (ƛ) gives 67.2 ohms expected. or about 1.3 SWR based upon 50 ohm unbalanced impedance to 67 ohm loading impedance.
So amongst the ruins of this post, the 1/2 W/L (ƛ) radiator element and its' airgap tuning rings then provide a much LOWER impedance adjustment than the 1/2 W (ƛ) "high impedance in the Kilo-ohmic range" to lower the SWR - against what looks to be a steady 1/4 wave "shorting coil" load that should give the tuned expected of 72 ohms (or less)
The 72 ohms is what a typical 1/4 wave dipole -center fed - exhibits - and that's being forgiving.
So since the LENGTH of 27MHz (at 1/2 ƛ) wavelength is TAD longer than 18 feet - Velocity versus Free air - still can't truly compensate for the shortened length - so it's apparent the capacitor and air gap - offset a length of radiator just under 1/2 wavelength in this package - so the impedance workout is about 900 ohms or just under 1kohm which would fool most meters into thinking you're at a close to 1:1 SWR - but the RESONATE length seems to be a little too short. So, to compensate that - they use a "capacitor" for coupling to the 1/2 Wave - the Inductive Coil added offsets this shortened length. Refer to photo - there's room in length to compress it in there...
There I said it...
I'd like to think all I need to do is update my notes...
"Don't beat me up too Much Scotty...
Uh, Scotty, I said Beat - not Beam...
Oh heck, pass the "Jim Beam" - we all need a shot.."​
Well, need a better photo - but from what I see you've got, is the Loading for a 1/4 wave ACROSS the 1/2 wave - with it's own loading coil. So between the winds, which needs a better photo to count those winds - the /14 wave provides a working impedance for the 1/2 Wave to Parallel against - like two coils with one tuned with a capacitor and an air gap to change the "reluctance" coupling the 1/4 wave loading and the 1/2 wave loading - together into one package.
So the 1/2 W/L expected of 1K ohm and 72 ohm of a dipole 1/4 w/l gives 67.2 ohms expected. or about 1.3 SWR based upon 50 ohm unbalanced impedance to 67 ohm loading impedance.
So amongst the ruins of this post, the 1/2 W/L radiator element and its' airgap tuning rings then provide a much LOWER impedance adjustment than the 1/2 W "high impedance in the Kilo-ohmic range" to lower the SWR - against what looks to be a steady 1/4 wave "shorting coil" load that should give the tuned expected of 72 ohms (or less)
So since the LENGTH of 27MHz wavelength is TAD longer than 18 feet - Velocity versus Free air - still can't truly compensate for the shortened length - so it's apparent the capacitor and air gap - offset a length of radiator just under 1/2 wavelength in this package - so the impedance workout is about 900 ohms or just under 1kohm which would fool most meters into thinking you're at a close to 1:1 SWR - but the RESONATE length seems to be a little too short. So, to compensate that - they use a "capacitor" for coupling to the 1/2 Wave - the Inductive Coil added offsets this shortened length. Refer to photo - there's room in length to compress it in there...
There I said it...
no matter the figures,my galaxy 99v and radioshack htx 100 get out well,setting on top of a sturdy piece of 2" pipe 30 ' from ground to mount,signal transmitted via Lm 400 low loss coax
http://www.radiomanual.info/schemi/ACC_antenna/Solarcon_A-99_review.pdf
"CLOSING STATEMENTS: The Antron 99 will NOT outperform any of the other typical 5/8 or 1/2 wave antennas like the popular 'Ringo'. However, for a modestly priced fiberglass antenna that is less visually intrusive than the 'ground plane' style antennas, it will certainly meet those needs"
" The Antron 99 has 1.8 dB gain on the horizon over an isotropic radiator. Referenced to a center-fed 1/2 wave dipole, which is the industry standard, the Antron 99 has a NEGATIVE gain of 0.3 dB."
Reactions: Greg T and Rwb
So using these figure in real terms:
Halfwave dipole with 100 watts to the antenna the,
Effective Radiated Power = 100.4 watts
The A99 with 100 watts to the antenna, the ERP = 93.4 watts
So using these numbers as totally correct, the A99 has a 7% LOSS over a dipole under equal conditions....???
Having compared side by side with the good OLD Ringo antenna, I tend to believe they are reasonably correct IMHO
Reactions: Rwb
That said, I suspect a listener on the other end would not be able to discern the difference between the 100.4 watt station and the 93.4 watt one.
Or, if using a typical barefoot CB, 4 watts and 3.72.
Yes Riverman, I would agree.
However, let us go a step further using these numbers.
Again using 100 watts to the antenna.
A half-wave ground plane having 1.5 dB gain over a Dipole...
ERP = 141.2 watts equates to a 34% increase over the A99
The 5/8ths ground plane having 2 dB gain over a Dipole...
ERP = 158.5 watts equates to a 41% increase over the A99
Now using these reasonable numbers we can begin to show a discernable difference if all antenna conditions are equal.
All the Best
Gary
I am not saying these are TRUE real-world numbers, just this old math major having fun playing with his pad and pencil.:LOL:
So since the LENGTH of 27MHz (at 1/2 ƛ) wavelength is TAD longer than 18 feet - Velocity versus Free air - still can't truly compensate for the shortened length - so it's apparent the capacitor and air gap - offset a length of radiator just under 1/2 wavelength in this package - so the impedance workout is about 900 ohms or just under 1kohm which would fool most meters into thinking you're at a close to 1:1 SWR - but the RESONATE lengthht seems to be a little too short. So, to compensate that - they use a "capacitor" for coupling to the 1/2 Wave - the Inductive Coil added offsets this shortened length. Refer to photo - there's room in length to compress it in there...
There I said it...
i will have to read that sevral times ..more photos here http://www.radiomanual.info/schemi/ACC_antenna/Solarcon_A-99_review.pdf
Reactions: Rwb
All the Best
Gary
10-4. Roger that.
Over and out. (y)
Reactions: Rwb
It works main thing. And im getting decent range with my a 99.dont tell it that its not good
Reactions: S&W357
The advertising claiming the 5/8 has db's of gain over other antennas is misleading or downright lies depending on how dumb the manufacturer is,
They use data from almost a century ago gleaned from ground mounted antennas over massive perfect groundplanes as a referance to BS you,
when you put them above real earth on poles with few radials that all goes out the window,
at the same tip height the 5/8 has a little less low angle gain than a dipole,
most of the difference seen in cb vertical antenna comparisons comes from the mast & coax radiating because folk don't install them correctly,
not because one antennas is way better than another similar length antenna as the cb antenna makers would have you believe.
Thank you...for a big guess on my end - I guess I owe an apology but too, looking over this the only error I see in my wording if from the 72 PRESUMED - it should have been more 50 ohms - but taking a look at the internals I can also understand why this thing just "radiates" in the down lead of coax too...
Now in the article, he mentions dBi - which is gain over Isotropic. I'm not even going to go there, it's in the realm of Dummy loads.
But I do see the correlation of 1/4 wave wound coil and it's impedance to run against - parallel to, the 1/2 Wave length radiator - the Capacitor assembly or the overall assembly - wow - you just can't make this stuff up.
Reactions: Rwb
"Most of the radiation is up in the sky at a high angle. The angle is so high, it is even useless for skywave.
This is a NEGATIVE gain antenna at low angles. A 1/4wl ground plane would seriously outperform the I-MAX 2000 or any other 1/2 or 5/8th wl antenna that does not have a large ground plane.
This pattern is over real earth, where a conventional dipole has about 8 to 8.5 dBi gain. This antenna about -2 dBd gain maximum. It has negative gain over a dipole. The gain over a dipole at most useful angles for DX is about -10 dB....significant negative gain."
~W8JI
I'll give you this. Any of these antennas (A99, Solorcon,Imax) are better than no antenna but nearly any antenna is better .
